Using Tables To Give Devices Large Amount of Tags
So I saw this post referencing that
And also
At the current time, I don’t believe we have enough users or devices for our plan to exceed the tag limit. However, I’m considering, for the future, a solution for storing user alerting preferences for each device they have access to.
For example:
I’m thinking that the best way to approach this would be to have the tag of a table id on the device linking to its table with all of its users’ stored preferences, similar to a foreign key.
My main question is: With the current structure and storage limitations, would this be the best approach to handle the scalability of storing user preferences?
I don’t think I would store any information on the device or the user object; instead, I would use a single data table with columns for experienceUserId and deviceId - as it sounds like what you want to store is per-user, per-device preferences. Then, other columns in the table could store whatever those key-value preference pairs are.
Then, when it comes time to save a user’s preferences, it’s a table upsert for the row matching the experienceUserId and deviceId.
As for sending alerts, the Device State Trigger could look up all rows matching the deviceId; iterate over them to see, given the preferences, which users should receive a notification; and then send those notifications. This last bit could get messy as your application achieves a greater scale, but some of those processes can be passed off to separate workflow runs using the Workflow Trigger Node.
what would be the purpose of triggering other workflows rather than running it all on one workflow? What are you suggesting should be split up?
The possibility of the flow timing out, as a single run can only go 60 seconds maximum. Theoretically at scale …
  • One device state report fetches hundreds, maybe thousands, of data table rows (one for each user with a preference matching the device ID)
  • A Function Node (most efficient in this scenario) determines which users need a notification given the returned preferences and the attribute value(s) in the state report
  • If, say, a hundred need a notification, that’s 100 requests to Twilio, SendGrid, a third-party API, or whatever it is you are doing to alert your users. This is where you run a timeout risk.
makes sense, thanks!
