@Zach_Jacobs awesome, thank you for the information!
You have two options here for bulk updating device tags. You can either:
- Construct a loop within the workflow and utilize Device nodes
- Build a schema and update using the API and
PATCH
Let’s jump into the specifics of each.
Loop
To create this logic in a workflow you would need to use a Loop Node. Within the Loop Node, you would likely do a device lookup with the Device: Get Node in order to retrieve your devices matching your tag query. You would then use the Device: Update Node to update the tags for your devices.
Schema
The Losant API Node includes the Device PATCH resource which allows you to build a schema to update tags in bulk. The schema looks like so:
"updateFields": {
"tags": [
"key": "TagKey",
"value": "TagValue"
"deviceIds": [
"575ecec57ae143cd83dc4a9f",
"575ecec57ae143cd83dc4a9e",
"575ecec57ae143cd83dc4a9a"
This would allow you to update in bulk, but you will have to create the logic to build the schema properly.
Let me know if I can assist further or if you have any additional questions.
Thanks!
