I currently use a workflow to receive Device:State messages that are filtered by an attribute named “request”. This looks for incoming messages with a “request” in the payload and depending on the type of request, it triggers a “Device: Update” block to update an individual DeviceTag or responds to the request with a “Device: Command” block to send data back to the Device. This works quite well but I would like to expand the functionality a bit. I would like the device itself to be able to update it’s own DeviceTags. I can already do this with individual tags but I want to expand to be able to support a wider range of incoming DeviceTags. I am currently trying to do this with the following incoming state message.
As seen in the image, I receive a “request”:“device_update_tags_req” with a “tag” object that includes all of the keys that I’d like to update. I’m not able to decode this in a way that’s usable and I really don’t understand the jsonEncode or stringify functions. I tried the jsonEncode blocks and it gets encoded as:
“json_object”:""[object Object]""
I have two questions:
- How can I parse this [object Object] into a usable JSON object?
- How can I generically update tags using a “Device: Update” block? Something like this where it pulls all the key names from the decoded json object and uses that key name as a template variable:
Hi @Zach_Jacobs,
I just have a couple of clarifying questions and comments to allow me to assist you further.
Let’s dive in! Are you currently reporting state to your device? Are you using device attributes or are you exclusively utilizing device tags?
It’s also important to know the /state topic is used exclusively for publishing device state. You can read a bit more about this within our documentation. You can see what the state payload should look like here. Are you reporting state on this topic and looking for a way to additionally update the tags?
@JuliaKempf,
Thanks for the quick response!
Yes, I am successfully using the state topic to update device attributes as well. I am looking for an additional way to update the tags. The state topic seemed to be the only way for me to figure out how to ingest messages into a workflow block for me to use. Is the best way to do this to create a custom topic and ingest using an MQTT block? If that’s the case I’d still like to be able to auto add incoming key value pairs as tags.
@Zach_Jacobs awesome, thank you for the information!
You have two options here for bulk updating device tags. You can either:
- Construct a loop within the workflow and utilize Device nodes
- Build a schema and update using the API and
PATCH
Let’s jump into the specifics of each.
Loop
To create this logic in a workflow you would need to use a Loop Node. Within the Loop Node, you would likely do a device lookup with the Device: Get Node in order to retrieve your devices matching your tag query. You would then use the Device: Update Node to update the tags for your devices.
Schema
The Losant API Node includes the Device PATCH resource which allows you to build a schema to update tags in bulk. The schema looks like so:
"updateFields": {
"tags": [
"key": "TagKey",
"value": "TagValue"
"deviceIds": [
"575ecec57ae143cd83dc4a9f",
"575ecec57ae143cd83dc4a9e",
"575ecec57ae143cd83dc4a9a"
This would allow you to update in bulk, but you will have to create the logic to build the schema properly.
Let me know if I can assist further or if you have any additional questions.
@JuliaKempf ,
That’s great! I was just typing out a response. I’m now ingesting the MQTT messages on a custom topic and decoding that into a proper JSON object. I have triggered a Device: Get block to get the device based on the incoming relayID so I have a reference to the actual device tags. I just need to ripple through the incoming “tags” and look for those existing keys on my device object and update them. I try both methods that you mentioned to see which works best for me
I got it working with the loop node. That is a huge help! Thanks so much!
