Hi there, probably pretty simple one but I seem to be stuck. I’ve attempting to use webook/slack integration so that from slack I can query a device value, and have it reply in slack. I’ve had success setting it up the messaging, but seem to be stuck on getting the actual data inserted into the reply.
I’m attaching a few screenshots showing my workflow and how I’ve set it up. Also you and see from my slack screenshot that something IS making it back, just not the device data I want included. Probably pretty basic, I tried searching the docs/forums but couldn’t find anything similar. Thanks!
The result of a Gauge Query is an object in the form:
"value": 7.175925925925926
The template you’re sending to Slack is pointing at the object instead of a specific property on the object. Therefore, when the platform attempts to convert it to a string, you get the default string representation of an object, which is [object Object].
If you want just the value, you can change the template to:
{{working.result.value}} is here
If you want to encode the object as a JSON string, you can use the jsonEncode helper:
{{jsonEncode working.result.value}} is here
Thanks, forgot the .value! That solved it and it’s working as expected.
Steve
