Updating tags with no value deletes the device tag
I have a dashboard with an input form that triggers a workflow to update some device tag values.
I had payload tag labelled incorrectly, so when I tried to update that tag without a corresponding payload value, it actually deleted the device tag completely.
Is this the desired functionality?
@Lars_Andersson,
If a tag is updated without a value (i.e. updating a tag without a corresponding payload value), the tag will be removed, as you have seen. Just as we do not allow you to save a device tag in the platform without a value:
This is currently how we have this feature implemented, so it is working correctly.
If this is not your desired functionality, I can certainly raise a ticket for this.
ok, that’s fine now when I know, but I was scratching my head a bit.
@Lars_Andersson I have this same issue, it actually caused me quite a headache, the next time the workflow runs I am trying to read tags which no longer exist and the workflow fails.
I have protected the system by adding stricter payload validation, hopefully removing the possibility that a tag value can ever be accidentally deleted, however it would be good to have a persistent tag, or perhaps the option for it.
No value tags could be useful for something like:
  • Target Email Address Tag
  • Target SMS Number Tag
  • Assigned to Customer Tag
Apologies, I meant to tag @Heath
