I’m working on Mongoose os with dallas temperature sensor DS18B20 and esp8266 nodemcu. I’m using js code and i’m able to get the sensor values to the device log of Mongoose. When i’m trying to publish the values to losant using Losant MQTT broker, I’m not able to do the same. Though I’ve given my device id as Losant device id and saved the configuration, it still says Published no topic to /esp8266_49C75D, this device id.
The device log is like this:
[Mar 17 12:23:08.121] bcn 0
[Mar 17 12:23:08.121] del if1
[Mar 17 12:23:08.123] usl
[Mar 17 12:23:08.123] add if1
[Mar 17 12:23:08.124] dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
[Mar 17 12:23:08.130] bcn 100
[Mar 17 12:23:08.130] mgos_wifi_dev_ap_set WiFi AP IP: 192.168.4.1/255.255.255.0 gw 192.168.4.1, DHCP range 192.168.4.2 - 192.168.4.100
[Mar 17 12:23:08.142] mgos_http_server_ini HTTP server started on [80]
[Mar 17 12:23:08.150] mg_rpc_channel_mqtt 0x3fff1934 esp8266_49C75D/rpc/#
[Mar 17 12:23:08.158] mg_rpc_channel_uart 0x3fff1cc4 UART0
[Mar 17 12:23:08.162] mgos_init Init done, RAM: 52096 total, 41652 free, 41056 min free
[Mar 17 12:23:09.406] mongoose_poll New heap free LWM: 15672
[Mar 17 12:23:11.403] Sensors found: 1
[Mar 17 12:23:11.614] Sensor# 0 address: 28ffe006a317046a
[Mar 17 12:23:12.286] Sensor# 0 Temperature: 28.130000 *C
[Mar 17 12:23:12.377] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.130000}}
[Mar 17 12:23:14.063] Sensor# 0 Temperature: 28.190000 *C
[Mar 17 12:23:14.153] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.190000}}
[Mar 17 12:23:16.063] Sensor# 0 Temperature: 28.190000 *C
[Mar 17 12:23:16.153] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.190000}}
[Mar 17 12:23:18.063] Sensor# 0 Temperature: 28.190000 *C
[Mar 17 12:23:18.154] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.190000}}
[Mar 17 12:23:20.063] Sensor# 0 Temperature: 28.190000 *C
[Mar 17 12:23:20.153] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.190000}}
[Mar 17 12:23:22.063] Sensor# 0 Temperature: 28.190000 *C
[Mar 17 12:23:22.153] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.190000}}
[Mar 17 12:23:24.063] Sensor# 0 Temperature: 28.190000 *C
[Mar 17 12:23:24.154] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.190000}}
[Mar 17 12:23:26.063] Sensor# 0 Temperature: 28.190000 *C
[Mar 17 12:23:26.153] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.190000}}
[Mar 17 12:23:28.063] Sensor# 0 Temperature: 28.190000 *C
[Mar 17 12:23:28.154] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.190000}}
[Mar 17 12:23:30.063] Sensor# 0 Temperature: 28.190000 *C
[Mar 17 12:23:30.154] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.190000}}
[Mar 17 12:23:32.064] Sensor# 0 Temperature: 28.190000 *C
[Mar 17 12:23:32.154] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.190000}}
[Mar 17 12:23:34.063] Sensor# 0 Temperature: 28.190000 *C
[Mar 17 12:23:34.153] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.190000}}
[Mar 17 12:23:36.063] Sensor# 0 Temperature: 28.190000 *C
[Mar 17 12:23:36.153] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.190000}}
[Mar 17 12:23:38.063] Sensor# 0 Temperature: 28.190000 *C
[Mar 17 12:23:38.153] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.190000}}
[Mar 17 12:23:40.063] Sensor# 0 Temperature: 28.190000 *C
[Mar 17 12:23:40.153] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.190000}}
[Mar 17 12:23:42.063] Sensor# 0 Temperature: 28.190000 *C
[Mar 17 12:23:42.153] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.190000}}
[Mar 17 12:23:44.063] Sensor# 0 Temperature: 28.190000 *C
[Mar 17 12:23:44.153] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.190000}}
[Mar 17 12:23:46.063] Sensor# 0 Temperature: 28.190000 *C
[Mar 17 12:23:46.159] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.190000}}
When i try to resave the configuration and flash it, the device log looks like this,
[Mar 17 12:26:42.512] save_cfg Saved to conf9.json
[Mar 17 12:26:42.628] mgos_vfs_umount_all Unmounting filesystems
[Mar 17 12:26:42.634] mgos_vfs_dev_close 0x3fff05c4 refs 0
[Mar 17 12:26:42.638] mgos_system_restart Restarting
[Mar 17 12:26:42.641] bcn 0
[Mar 17 12:26:42.642] del if1
[Mar 17 12:26:42.643] usl
[Mar 17 12:26:42.743]
[Mar 17 12:26:42.744] ets Jan 8 2013,rst cause:2, boot mode:(3,7)
[Mar 17 12:26:42.748]
[Mar 17 12:26:42.765] load 0x40100000, len 1796, room 16
[Mar 17 12:26:42.769] tail 4
[Mar 17 12:26:42.770] chksum 0x63
[Mar 17 12:26:42.770] load 0x3ffe8000, len 824, room 4
[Mar 17 12:26:42.773] tail 4
[Mar 17 12:26:42.775] chksum 0x0c
[Mar 17 12:26:42.775] csum 0x0c Q Z jUJ B TTTTj-kVVU U (TT U U TT U+UZ I UEJ KP JZ E T P Z - P QT Z V UP RQQU T N { N| l lld` c | r l n N l { l l mode : sta(60:01:94:49:c7:5d) + softAP(62:01:94:49:c7:5
[Mar 17 12:26:42.890] esp_mgos_init2 example-arduino-dallas-temperature-js-1.18 1.0 (20180314-185435/???)
[Mar 17 12:26:42.896] esp_mgos_init2 Mongoose OS 2018031418 (20180314-185435/???)
[Mar 17 12:26:42.902] esp_mgos_init2 SDK 2.1.0(ce90efd); flash: 4M; RAM: 52096 total, 47700 free
[Mar 17 12:26:42.910] esp_print_reset_info Reset cause: 4 (soft reset)
[Mar 17 12:26:42.916] mgos_vfs_dev_open sysflash () -> 0x3fff05c4
[Mar 17 12:26:42.920] mgos_vfs_mount Mount SPIFFS @ / (dev 0x3fff05c4, opts {"addr": 32768, "size": 262144}) -> 0x3fff05d4
[Mar 17 12:26:42.988] mgos_vfs_mount /: size 233681, used: 130269, free: 103412
[Mar 17 12:26:43.081] mgos_sys_config_init MAC: 62019449C75D
[Mar 17 12:26:43.085] mgos_sys_config_init WDT: 30 seconds
[Mar 17 12:26:43.089] mgos_mdns_init Listening on udp://:5353
[Mar 17 12:26:43.094] mgos_mdns_hal_join_g Joining multicast group 224.0.0.251
[Mar 17 12:26:43.101] mgos_i2c_create I2C GPIO init ok (SDA: 12, SCL: 14)
[Mar 17 12:26:43.107] mgos_aws_init AWS Greengrass enable (0)
[Mar 17 12:26:43.111] bcn 0
[Mar 17 12:26:43.112] del if1
[Mar 17 12:26:43.114] scandone
[Mar 17 12:26:43.114] del if0
[Mar 17 12:26:43.114] usl
[Mar 17 12:26:43.114] mode : null
[Mar 17 12:26:43.116] mgos_wifi_set_config WiFi mode: STA
[Mar 17 12:26:43.120] mgos_wifi_set_mode WiFi mode: STA
[Mar 17 12:26:43.123] mode : sta(60:01:94:49:c7:5d)
[Mar 17 12:26:43.125] add if0
[Mar 17 12:26:43.127] WPA2 ENTERPRISE VERSION: [v2.0] disable
[Mar 17 12:26:43.129] mgos_wifi_setup_sta WiFi STA: Connecting to JioFi4_1076A8
[Mar 17 12:26:43.137] mgos_http_server_ini HTTP server started on [80]
[Mar 17 12:26:43.146] mg_rpc_channel_mqtt 0x3fff1504 5aa9876c5f623600074b3fbd/rpc/#
[Mar 17 12:26:43.154] mg_rpc_channel_uart 0x3fff18ac UART0
[Mar 17 12:26:43.158] mgos_init Init done, RAM: 52096 total, 42712 free, 41056 min free
[Mar 17 12:26:44.248] mongoose_poll New heap free LWM: 17152
[Mar 17 12:26:44.256] mgos_net_on_change_c WiFi STA: connecting
[Mar 17 12:26:46.246] Sensors found: 1
[Mar 17 12:26:46.457] Sensor# 0 address: 28ffe006a317046a
[Mar 17 12:26:47.130] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:26:47.221] Published: no topic: /losant/5aa9876c5f623600074b3fbd/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:26:47.386] scandone
[Mar 17 12:26:48.270] state: 0 -> 2 (b0)
[Mar 17 12:26:48.938] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:26:49.017] Published: no topic: /losant/5aa9876c5f623600074b3fbd/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:26:49.270] state: 2 -> 0 (2)
[Mar 17 12:26:49.272] reconnect
[Mar 17 12:26:49.274] scandone
[Mar 17 12:26:49.278] mgos_net_on_change_c WiFi STA: disconnected
[Mar 17 12:26:49.284] mgos_net_on_change_c WiFi STA: connecting
[Mar 17 12:26:50.902] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:26:50.981] Published: no topic: /losant/5aa9876c5f623600074b3fbd/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:26:52.092] scandone
[Mar 17 12:26:52.094] state: 0 -> 2 (b0)
[Mar 17 12:26:52.096] state: 2 -> 3 (0)
[Mar 17 12:26:52.102] state: 3 -> 5 (10)
[Mar 17 12:26:52.104] add 0
[Mar 17 12:26:52.104] aid 2
[Mar 17 12:26:52.104] cnt
[Mar 17 12:26:52.118]
[Mar 17 12:26:52.118] connected with JioFi4_1076A8, channel 11
[Mar 17 12:26:52.122] dhcp client start...
[Mar 17 12:26:52.124] mgos_net_on_change_c WiFi STA: connected
[Mar 17 12:26:52.903] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:26:52.980] Published: no topic: /losant/5aa9876c5f623600074b3fbd/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:26:54.902] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:26:54.981] Published: no topic: /losant/5aa9876c5f623600074b3fbd/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:26:54.996] ip:192.168.225.45,mask:255.255.255.0,gw:192.168.225.1
[Mar 17 12:26:55.000] mgos_net_on_change_c WiFi STA: ready, IP 192.168.225.45, GW 192.168.225.1, DNS 192.168.225.1
[Mar 17 12:26:55.010] mgos_mqtt_global_con MQTT connecting to broker.losant.com:1883
[Mar 17 12:26:56.045] mgos_sntp_query SNTP query to pool.ntp.org
[Mar 17 12:26:56.190] mgos_sntp_ev SNTP reply from 123.108.200.124: time 1521269815.292536, local 13.435059, delta 1521269801.857477
[Mar 17 12:26:56.916] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:26:56.995] Published: no topic: /losant/5aa9876c5f623600074b3fbd/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:03.298] bcn 0
[Mar 17 12:27:03.298] del if1
[Mar 17 12:27:03.300] usl
[Mar 17 12:27:03.300] add if1
[Mar 17 12:27:03.301] dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
[Mar 17 12:27:03.307] bcn 100
[Mar 17 12:27:03.307] mgos_wifi_dev_ap_set WiFi AP IP: 192.168.4.1/255.255.255.0 gw 192.168.4.1, DHCP range 192.168.4.2 - 192.168.4.100
[Mar 17 12:27:03.319] mgos_http_server_ini HTTP server started on [80]
[Mar 17 12:27:03.327] mg_rpc_channel_mqtt 0x3fff1934 esp8266_49C75D/rpc/#
[Mar 17 12:27:03.335] mg_rpc_channel_uart 0x3fff1cc4 UART0
[Mar 17 12:27:03.339] mgos_init Init done, RAM: 52096 total, 41652 free, 41056 min free
[Mar 17 12:27:04.585] mongoose_poll New heap free LWM: 15672
[Mar 17 12:27:06.579] Sensors found: 1
[Mar 17 12:27:06.790] Sensor# 0 address: 28ffe006a317046a
[Mar 17 12:27:07.463] Sensor# 0 Temperature: 28.250000 *C
[Mar 17 12:27:07.553] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.250000}}
[Mar 17 12:27:09.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:09.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:11.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:11.331] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:13.241] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:13.331] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:15.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:15.331] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:17.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:17.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:19.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:19.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:21.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:21.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:23.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:23.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:25.241] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:25.331] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:27.239] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:27.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:29.239] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:29.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:31.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:31.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:33.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:33.331] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:35.239] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:35.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:37.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:37.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:39.239] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:39.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:41.239] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:41.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:43.242] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:43.331] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:45.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:45.331] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:47.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:47.331] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:49.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:49.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:51.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:51.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:53.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:53.331] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:55.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:55.331] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:57.239] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:57.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:27:59.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:27:59.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:01.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:01.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:03.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:03.331] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:05.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:05.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:07.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:07.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:09.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:09.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:11.239] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:11.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:13.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:13.331] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:15.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:15.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:17.239] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:17.329] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:19.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:19.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:21.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:21.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:23.248] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:23.331] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:25.239] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:25.329] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:27.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:27.332] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:29.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:29.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:31.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:31.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:33.240] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:33.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:35.239] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:35.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:37.239] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:37.329] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
[Mar 17 12:28:39.239] Sensor# 0 Temperature: 28.310000 *C
[Mar 17 12:28:39.330] Published: no topic: /losant/esp8266_49C75D/state message: {"data":{"temperature":28.310000}}
If observed, when i re-save the configuration initially the device id changes to losant device id but again it changes back to /esp8266_49C75D.
Can you please help me with this isssue?
