i have an issue when trying to trigger a workflow through the input controls on the dashboard, it returns a JSON template error.
my payload is as follows:
“HVACsetpoint”:{{HVACsetpoint}},
“indoorLights”:{{indoorLights}},
“outdoorLights”:{{outdoorLights}},
“HVACstatus”:{{HAVCstatus}}
^^ Is that your error? All the other properties in your object match the names of the values except this one.
{{HAVCstatus}} is populated by a select input, which means its value will be a string. That is where your JSON error is coming from. The value needs to either be wrapped in quotes ( “{{HAVCstatus}}” ), or you need to use a {{jsonEncode}} helper for the value.
