When setting the throttle node to 1 sec and then save the workflow, next time I open that node it says Throttling to 1 sec, correctly, but Rate and Unit fields defaults back to 60 min
Hey @Lars_Andersson,
Thanks for pointing this out!
I do just want to mention that 60 per minute is still 1 per second, but I do agree that once revisiting the node, the fields should remain the same as previously chosen. I’ve raised a ticket for this and will keep you informed with any information I learn.
