I would love to see the feature of being able to add some fixed lines to a line chart, to show a min or max line for example, without having to use an attribute.
In a similar way I would like to see this in a gauge too. I know it can change color.
These “static” line values should be able to be controlled by a context variable or device tag.
This is a great idea. I will double-check, but we may already have a feature request open for this. If so, I’ll add your +1 to it. If not, I will make this feature request and keep you updated with what I learn.
In the meantime, you could have an attribute be a static value, by either always reporting the same value with the firmware you have, or by using the Device: State Node in a workflow.
