Should I be able to use server type MySql for a MariaDB?
We have not explicitly tested MariaDB. The client API is advertised as compatible with MySQL, so in theory it may work. This is something you’ll have to test yourself.
OK, I switched to MySQL instead.
Now I get the error:
SQLNodeError
ER_NOT_SUPPORTED_AUTH_MODE: Client does not support authentication protocol requested by server; consider upgrading MySQL client
Can you please provide the authentication mechanism that your MySQL database is currently configured with?
I figured it out, I had to switch back to Standard authentication for the username I used, to get it working.
Any info on how I should do it if I wanted to use SSL/TLS ?
I would expect checking the TLS/SSL checkbox and then providing a username and password is all that would be required. Is that what you did to receive the previous error message?
No, I wasn’t sure how to do it. The user I was using was setup for secure password authentication on the Mysql server side.
I believe using secure password authentication on the server side, then checking the TLS/SSL box in node configuration is the required combo to get a secure connection.
If that’s the case, how should I configure the “additional configuration method” box?
Or is that optional?
Those options are based on this:
Properly setting up SSL for you MySQL server and obtaining your CA certificate is a bit beyond the level of support we can provide. The quickest option during development, however, is to pass { rejectUnauthorized: false } through those options.
In production, you will eventually want to pass another parameter, ca, which is the contents of your CA certificate.
