When I compile the losant-kit-lcd sketch I am receiving the following errors.
losant-kit-lcd:55: error: 'handleCommand' was not declared in this scope
losant-kit-lcd:56: error: 'connect' was not declared in this scope
connect();
Hi! Can you post or link to the contents of your file? ( removing sensitive data/keys )
It looks like you don’t have the handleCommand and connect functions.
Workshop example for periodically sending temperature data and displaying
on an LCD.
Visit https://www.losant.com/kit for full instructions.
Copyright (c) 2016 Losant IoT. All rights reserved.
#include <ESP8266WiFi.h>
#include <LiquidCrystal_I2C.h>
#include <Losant.h>
// WiFi credentials.
const char* WIFI_SSID = "my-wifi-ssid";
const char* WIFI_PASS = "my-wifi-pass";
// Losant credentials.
const char* LOSANT_DEVICE_ID = "my-device-id";
const char* LOSANT_ACCESS_KEY = "my-access-key";
const char* LOSANT_ACCESS_SECRET = "my-access-secret";
// Construct an LCD object and pass it the
// I2C address, width (in characters) and
// height (in characters). Depending on the
// Actual device, the IC2 address may change.
LiquidCrystal_I2C lcd(0x3F, 16, 2);
WiFiClientSecure wifiClient;
void setup() {
Serial.begin(115200);
// Giving it a little time because the serial monitor doesn't
// immediately attach. Want the workshop that's running to
// appear on each upload.
delay(2000);
Serial.println();
Serial.println("Running LCD Kit Firmware.");
// The begin call takes the width and height. This
// Should match the number provided to the constructor.
lcd.begin(16, 2);
lcd.init();
// Turn on the backlight.
lcd.backlight();
connect();
int timeSinceLastRead = 0;
int tempSum = 0;
int tempCount = 0;
void loop() {
bool toReconnect = false;
toReconnect = true;
if (!device.connected()) {
toReconnect = true;
if (toReconnect) {
connect();
device.loop();
tempSum += analogRead(A0);
tempCount++;
// Report every 15 seconds.
if (timeSinceLastRead > 15000) {
// Take the average reading over the last 15 seconds.
double raw = (double)tempSum / (double)tempCount;
// The tmp36 documentation requires the -0.5 offset, but during
// testing while attached to the MCU, all tmp36 sensors
// required a -0.52 offset for better accuracy.
double degreesC = (((raw / 1024.0) * 3.2) - 0.5) * 100.0;
double degreesF = degreesC * 1.8 + 32;
reportTemp(degreesC, degreesF);
tempSum = 0;
tempCount = 0;
delay(1000);
timeSinceLastRead += 1000;
if (strcmp(command->name, "refresh") == 0) {
payload.printTo(Serial);
// Clear the screen.
lcd.clear();
// Move the cursor to the start of the first line and print the text.
lcd.setCursor(0,0);
lcd.print(payload["L1"].asString());
// Move the cursor to the start of the second line and print the text.
lcd.setCursor(0,1);
lcd.print(payload["L2"].asString());
* Connect to WiFi and Losant
void connect() {
// Connect to Wifi.
Serial.println();
Serial.println();
Serial.println(WIFI_SSID);
// Check to see if
Serial.println();
Serial.print("SSID: ");
Serial.print("Password: ");
Serial.println(WIFI_PASS);
Serial.println();
Serial.println("Trying again...");
delay(10000);
delay(500);
Serial.println("...");
Serial.println();
Serial.println();
HTTPClient http;
"deviceId": "575ecf887ae143cd83dc4aa2",
"key": "this_would_be_the_key",
"secret": "this_would_be_the_secret"
String buffer;
root.printTo(buffer);
if (httpCode > 0) {
if (httpCode == HTTP_CODE_OK) {
} else {
if (httpCode == 400) {
} else if (httpCode == 401) {
} else {
} else {
http.end();
// Connect to Losant.
Serial.println();
while (!device.connected()) {
delay(500);
Serial.print(".");
Serial.println("Connected!");
Serial.println();
* Report Temperature to Losant
* @param degreesC double
* @param degreesF double
void reportTemp(double degreesC, double degreesF) {
Serial.println();
Serial.print("Temperature C: ");
Serial.println(degreesC);
Serial.print("Temperature F: ");
Serial.println(degreesF);
Serial.println();
root["tempC"] = degreesC;
root["tempF"] = degreesF;
device.sendState(root);
lcd.setCursor(14,1);
lcd.print(degreesF);
when I posted the code, it didn’t past the include section correctly.
#include <Losant.h>
The code that you posted compiled for me. Are you using the Arduino IDE? Also, what’s your environment?
I am using the Arduino IDE version 1.6.7
with Windows 10 as the O/S
Where is the handleCommand called from? is it in one of the includes?
The handleCommand is defined in the file you are using.
Could you update your Arduino IDE? The most up-to-date version is 1.8.1
Also, depending on your settings. Arduino may not like functions being used before they are defined. If that’s the case, this should work:
on an LCD.
#include <Losant.h>
int tempSum = 0;
int tempCount = 0;
void loop() {
toReconnect = true;
toReconnect = true;
if (toReconnect) {
connect();
device.loop();
tempCount++;
tempSum = 0;
tempCount = 0;
delay(1000);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
void connect() {
// Connect to Wifi.
Serial.println();
Serial.println();
// Check to see if
Serial.println();
Serial.println();
delay(10000);
delay(500);
Serial.println();
Serial.println();
HTTPClient http;
String buffer;
if (httpCode > 0) {
} else {
} else {
} else {
http.end();
Serial.println();
delay(500);
Serial.print(".");
Serial.println();
Serial.println();
Serial.println();
void setup() {
delay(2000);
Serial.println();
lcd.begin(16, 2);
lcd.init();
lcd.backlight();
connect();
Seems likw upgrading the IDE to 1.8.1 did the trick! Thanks for your help.
