Is there a way to integrate Losan to another web-based system with web services that exposes a SOAP API?
Can we use the http node for that?
Hi @paul_wareham,
This is possible. You should be able to use a combination of the HTTP node and the HTML/XML Parse Node.
Just a secondary note, make sure you set the proper content-type
