Being able to resize workflow nodes would improve readability, not only for individual nodes but also for the overall workflow. It’s frustrating that the node’s label is truncated for most of my workflow’s node and there’s not a way to make the node any wider so that the entire label is displayed. Also, trying to line up nodes under a switch node’s case sub-nodes is awkward since the case sub-nodes aren’t as wide as a normal stand-alone node. Being able to at least widen a node would greatly help with making control/execution paths vertically aligned under their associated case sub-node.
Hi @Paul_Muschick,
I will create a feature request for this functionality, I agree it could be quite valuable. I will follow up should this feature request be implemented in the near future.
Please let me know if you have any further questions.
Thanks so much!
