I’m setting up a whitelist of open ports for our IoT device. Does anyone have a list of required open ports for the Losant platform to work.
- Thanks
Hey @PhillipKB,
How your devices will connect & communicate with the Losant Platform will dictate which ports you will need to whitelist.
That being said, here’s a list from our documentation:
MQTT
1883
8883
Others
80
443
You will likely only need to whitelist one port depending on your use case. If you’re using MQTT, I would highly recommend you use port 8883.
