I tried to run the way you suggested. Thanks
However, my notebook run keeps failing as in the attached result.log. The notebook perfectly runs outside in a standalone Jupyter notebook.
results.log
[NbConvertApp] Converting notebook /tmp/input.ipynb to notebook
Traceback (most recent call last):
File "/opt/conda/bin/jupyter-nbconvert", line 11, in <module>
sys.exit(main())
File "/opt/conda/lib/python3.9/site-packages/jupyter_core/application.py", line 264, in launch_instance
return super(JupyterApp, cls).launch_instance(argv=argv, **kwargs)
File "/opt/conda/lib/python3.9/site-packages/traitlets/config/application.py", line 846, in launch_instance
app.start()
File "/opt/conda/lib/python3.9/site-packages/nbconvert/nbconvertapp.py", line 361, in start
self.convert_notebooks()
File "/opt/conda/lib/python3.9/site-packages/nbconvert/nbconvertapp.py", line 533, in convert_notebooks
self.convert_single_notebook(notebook_filename)
File "/opt/conda/lib/python3.9/site-packages/nbconvert/nbconvertapp.py", line 498, in convert_single_notebook
output, resources = self.export_single_notebook(notebook_filename, resources, input_buffer=input_buffer)
File "/opt/conda/lib/python3.9/site-packages/nbconvert/nbconvertapp.py", line 427, in export_single_notebook
output, resources = self.exporter.from_filename(notebook_filename, resources=resources)
File "/opt/conda/lib/python3.9/site-packages/nbconvert/exporters/exporter.py", line 186, in from_filename
return self.from_file(f, resources=resources, **kw)
File "/opt/conda/lib/python3.9/site-packages/nbconvert/exporters/exporter.py", line 204, in from_file
return self.from_notebook_node(nbformat.read(file_stream, as_version=4), resources=resources, **kw)
File "/opt/conda/lib/python3.9/site-packages/nbconvert/exporters/notebook.py", line 32, in from_notebook_node
nb_copy, resources = super().from_notebook_node(nb, resources, **kw)
File "/opt/conda/lib/python3.9/site-packages/nbconvert/exporters/exporter.py", line 143, in from_notebook_node
nb_copy, resources = self._preprocess(nb_copy, resources)
File "/opt/conda/lib/python3.9/site-packages/nbconvert/exporters/exporter.py", line 323, in _preprocess
nbc, resc = preprocessor(nbc, resc)
File "/opt/conda/lib/python3.9/site-packages/nbconvert/preprocessors/base.py", line 47, in __call__
return self.preprocess(nb, resources)
File "/opt/conda/lib/python3.9/site-packages/nbconvert/preprocessors/execute.py", line 84, in preprocess
self.preprocess_cell(cell, resources, index)
File "/opt/conda/lib/python3.9/site-packages/nbconvert/preprocessors/execute.py", line 105, in preprocess_cell
cell = self.execute_cell(cell, index, store_history=True)
File "/opt/conda/lib/python3.9/site-packages/nbclient/util.py", line 84, in wrapped
return just_run(coro(*args, **kwargs))
File "/opt/conda/lib/python3.9/site-packages/nbclient/util.py", line 62, in just_run
return loop.run_until_complete(coro)
File "/opt/conda/lib/python3.9/asyncio/base_events.py", line 642, in run_until_complete
return future.result()
File "/opt/conda/lib/python3.9/site-packages/nbclient/client.py", line 854, in async_execute_cell
self._check_raise_for_error(cell, exec_reply)
File "/opt/conda/lib/python3.9/site-packages/nbclient/client.py", line 756, in _check_raise_for_error
raise CellExecutionError.from_cell_and_msg(cell, exec_reply_content)
nbclient.exceptions.CellExecutionError: An error occurred while executing the following cell:
#!/usr/bin/env python
import requests
import json
class MahaDiscom(object):
""" Class to get det
ails about Mahadiscom """
def __init__(self, cn, bun, ct):
""" __init__ """
self.serverurl = 'https://wss.mahadiscom.in/wss/'
self.con_details = {
'ConsumerNo': cn,
'BuNumber': bun,
'consumerType': ct,
def is_consumer_valid(self):
Check if consumer is valid or not
returns : True if consumer is valid
False if consumer is not valid
actionurl = 'wss?uiActionName=validateConsumerNumberHTLT&IsAjax=true'
url = self.serverurl + actionurl
response = requests.post(url, data=self.con_details)
if response.status_code != 200 or response.text == 'false':
return False
elif response.text == 'true':
return True
def get_bill_details(self):
Get bill details
returns : a dictionary with consumer's bill details
billdetails = {}
actionurl = "wss?uiActionName=viewImpExpInformation&IsAjax=true"
try:
billdetails = json.loads(response.text)
except ValueError as err:
print("Unable to parse json response " + str(err))
return {}
if response.status_code == 200:
return billdetails
print("ERROR: Return code is Non-2xx : %d" % response.status_code)
return {}
def main():
mahadiscom = MahaDiscom(cn='266513040164',bun='4016', ct='LT')
billdetails = mahadiscom.get_bill_details()
return billdetails
#i = 0
#print (len(billdetails))
#while i < len(billdetails):
#jo=json.loads(billdetails[i])
#print(billdetails[i]["BILL_MONTH"]+" "+str(billdetails[i]["BILL_YEAR"]))
#print("EXP " + str(billdetails[i]["EXP_UNITS_KWH_TOTAL"]))
#print("IMP "+ str(billdetails[i]["IMP_UNITS_KWH_TOTAL"]))
#print("GEN "+str(billdetails[i]["GEN_UNITS_KWH_TOTAL"]))
#print("----------")
#i += 1
if __name__ == "__main__":
#data = {}
#data = main()
#return data
main()
gaierror Traceback (most recent call last)
/opt/conda/lib/python3.9/site-packages/urllib3/connection.py in _new_conn(self)
173 try:
--> 174 conn = connection.create_connection(
175 (self._dns_host, self.port), self.timeout, **extra_kw
/opt/conda/lib/python3.9/site-packages/urllib3/util/connection.py in create_connection(address, timeout, source_address, socket_options)
72
---> 73 for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
74 af, socktype, proto, canonname, sa = res
/opt/conda/lib/python3.9/socket.py in getaddrinfo(host, port, family, type, proto, flags)
953 addrlist = []
--> 954 for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
955 af, socktype, proto, canonname, sa = res
gaierror: [Errno -3] Temporary failure in name resolution
During handling of the above exception, another exception occurred:
NewConnectionError Traceback (most recent call last)
/opt/conda/lib/python3.9/site-packages/urllib3/connectionpool.py in urlopen(self, method, url, body, headers, retries, redirect, assert_same_host, timeout, pool_timeout, release_conn, chunked, body_pos, **response_kw)
698 # Make the request on the httplib connection object.
--> 699 httplib_response = self._make_request(
700 conn,
/opt/conda/lib/python3.9/site-packages/urllib3/connectionpool.py in _make_request(self, conn, method, url, timeout, chunked, **httplib_request_kw)
381 try:
--> 382 self._validate_conn(conn)
383 except (SocketTimeout, BaseSSLError) as e:
/opt/conda/lib/python3.9/site-packages/urllib3/connectionpool.py in _validate_conn(self, conn)
1009 if not getattr(conn, "sock", None): # AppEngine might not have `.sock`
-> 1010 conn.connect()
1011
/opt/conda/lib/python3.9/site-packages/urllib3/connection.py in connect(self)
357 # Add certificate verification
--> 358 conn = self._new_conn()
359 hostname = self.host
185 except SocketError as e:
--> 186 raise NewConnectionError(
187 self, "Failed to establish a new connection: %s" % e
NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7f872f59ab20>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
MaxRetryError Traceback (most recent call last)
/opt/conda/lib/python3.9/site-packages/requests/adapters.py in send(self, request, stream, timeout, verify, cert, proxies)
438 if not chunked:
--> 439 resp = conn.urlopen(
440 method=request.method,
754
--> 755 retries = retries.increment(
756 method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
/opt/conda/lib/python3.9/site-packages/urllib3/util/retry.py in increment(self, method, url, response, error, _pool, _stacktrace)
573 if new_retry.is_exhausted():
--> 574 raise MaxRetryError(_pool, url, error or ResponseError(cause))
575
MaxRetryError: HTTPSConnectionPool(host='wss.mahadiscom.in', port=443): Max retries exceeded with url: /wss/wss?uiActionName=viewImpExpInformation&IsAjax=true (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f872f59ab20>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
/tmp/ipykernel_15/2811413364.py in <module>
71 #data = main()
72 #return data
---> 73 main()
74
75
/tmp/ipykernel_15/2811413364.py in main()
53 def main():
54 mahadiscom = MahaDiscom(cn='266513040164',bun='4016', ct='LT')
---> 55 billdetails = mahadiscom.get_bill_details()
56 return billdetails
57 #i = 0
/tmp/ipykernel_15/2811413364.py in get_bill_details(self)
38 actionurl = "wss?uiActionName=viewImpExpInformation&IsAjax=true"
39 url = self.serverurl + actionurl
---> 40 response = requests.post(url, data=self.con_details)
41 try:
42 billdetails = json.loads(response.text)
/opt/conda/lib/python3.9/site-packages/requests/api.py in post(url, data, json, **kwargs)
115 """
116
--> 117 return request('post', url, data=data, json=json, **kwargs)
118
119
/opt/conda/lib/python3.9/site-packages/requests/api.py in request(method, url, **kwargs)
59 # cases, and look like a memory leak in others.
60 with sessions.Session() as session:
---> 61 return session.request(method=method, url=url, **kwargs)
62
63
/opt/conda/lib/python3.9/site-packages/requests/sessions.py in request(self, method, url, params, data, headers, cookies, files, auth, timeout, allow_redirects, proxies, hooks, stream, verify, cert, json)
540 }
541 send_kwargs.update(settings)
--> 542 resp = self.send(prep, **send_kwargs)
543
544 return resp
/opt/conda/lib/python3.9/site-packages/requests/sessions.py in send(self, request, **kwargs)
653
654 # Send the request
--> 655 r = adapter.send(request, **kwargs)
656
657 # Total elapsed time of the request (approximately)
514 raise SSLError(e, request=request)
515
--> 516 raise ConnectionError(e, request=request)
517
518 except ClosedPoolError as e:
ConnectionError: HTTPSConnectionPool(host='wss.mahadiscom.in', port=443): Max retries exceeded with url: /wss/wss?uiActionName=viewImpExpInformation&IsAjax=true (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f872f59ab20>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
Jupyter exited with status code: 1
