Hi all, there are many services that requires OAuth authentication before to work with their API, I mean, do some
Get request or Put some data in their accounts. Google and Microsoft are good examples of this kind of API’s. I’m trying to design a workflow to cover Google OAuth. On this link there is a good explanation of this procedure. https://developers.google.com/identity/protocols/OAuth2WebServer#creatingcred
A complete OAuth procedure have different task, one for “code” request, next one for “exchange a code” for a valid “token” and with this you can build http request during a valid period of time and after this expires you also must to renew this “token” periodically before this expires. So, seems to be razonable to create a workflow for each of them or not?. Is this possible to share data between workflows ?. “Store value” and “Get value” nodes only have a workflow environment but does not possible to share in between? . What it is the best strategy to solve this?
An a second questions is related with a solution deploy. If I want provide this solution for many devices, I mean, many devices connected to many different calendars accounts, then I’ll need one set of workflows for each of them ?? or I can execute this workflow (with the different parameter call for each of them) one time for any device ?.
thanks,
