is there any way to make this link shorter ?
moreover, i can download this image when I click it from device attributes, but when I click it from dashboard I receive this message :
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<Error>
<Code>AccessDenied</Code>
<Message>Access denied.</Message>
<Details>
Anonymous caller does not have storage.objects.get access to the Google Cloud Storage object.
Permission 'storage.objects.get' denied on resource (or it may not exist).
</Details>
</Error>
Kindly advice
There is not a way to make the link itself shorter, but you can use markdown to change what’s displayed. In the cell template, you would do:
[Your Custom Text]({{value}})
This is because the default template, {{format value}} will result in special characters being escaped, resulting in an invalid URL. You can fix it two ways:
- Switch the template to
{{{value}}} (notice the triple curly braces to remove escaping)
- Use the Markdown syntax above.
Details on Handlebar HTML escaping can be found here:
https://handlebarsjs.com/guide/#html-escaping
