I’d like to be able to have the option of selecting the image URL using either a string or blob attribute from a device. I’m trying to solve the problem of showing the current floor plan a device is located at specific points in time. So if the device is on Floor 1 now, if I set the time to 60 mins ago it will change the image to show the device is on Floor 2.
Hello @steen_cummings1,
I just want to make sure that I understand your use case correctly. You’re looking to dynamically update the image in an Image Overlay Dashboard Block based on a devices current location, and you would like to be able to update the image URL via a device attribute, correct?
I’ll make a feature request with out engineering team for this, and I will be sure to reach out to you as I learn more about it!
If you’re working with Device Context, you can use a context variable in the Image URL for that block, and update the URL from a device tag:
Let me know if you have any questions.
Thanks heath. Originally I was using the context variables for the image so it could be dynamic. If I use device context, are the tags’ state stored as timeseries like attributes? So if I was to set the dashboard time’s current time to 30 minutes prior, it will use the device tags at that point in time (and not the latest tags)?
Hi @steen_cummings1,
Ah, this is a good point. Tags are not stored as time-series data, and you would not be able to go back 30 minutes prior and see the last Tag value without keeping some record of previous tags.
I did make this a feature request, though. So I will be sure to update you with anything I learn!
