article https://www.losant.com/blog/getting-started-with-the-lifx-remote-api-and-losant
mentions a LIFX Custom Node.
Is that available somewhere?
Hi @Lars_Andersson,
I have attached an export of that custom node below. Keep in mind that this was created for use within the context of the blog article.
lifx.node (12.9 KB)
I got the API working, so I moved on the article:
Should the function node contain all the code segments together?
I couldn’t see a link to the complete function node anywhere.
Hi @Lars_Andersson,
That is correct, all of the code snippets in that blog are from the Function Node. If you combine all of them, you will have the full code.
