Industrial equipment monitor worklow question
Hi there,
I loaded the Industrial Equipment Monitor template and enabled the 2 minutes periodic Workflow called Simulated Devices.
However I am puzzled by the flow for the 2 reasons:
  • where does it change the device status? the only output node I see is debug?
  • where does it generate the random numbers for each properties?
Thanks.
If you look inside the Loop Node on the canvas, you will see the set of nodes for generating the random data and for writing state for each returned device using the Device: State Node.
Ah I totally missed that, I just needed to double click!
