I build this project and workflow https://www.losant.com/blog/getting-started-with-the-esp8266-and-dht22-sensor, it sends emails when the temprature exceeds set limit. it works well. I need help to connect three DS18B20 to Losant.
Hi, where specifically do you need help? Is it wiring the sensor to the device? Parsing the data that’s coming through the sensor into the pin?
Hi, many thanks for your prompt reply. I have already built the device with three sensors and ESP8266. Getting temperatures from serial monitor. I need help to integrate it with Losant.
