I’m trying to leverage GPS attributes in a dashboard indicator block. However the queries for the GPS attributes return the coordinates with a space between the Lat/Lon. This breaks markdown links with the GPS location added, as well as other GPS string helpers (like distance between 2 points). Any suggestions on how to remove the whitespace?
https://www.google.com/maps/dir/{{value-0}}/{{value-1}}
Yields:
https://www.google.com/maps/dir/42.48608, -96.34718/42.485, -96.34639
Can you please provide an example of what markdown / helpers aren’t working for you with the [space] in place?
I tried to do that in the original post. value-0 and value-1 are both GPS attributes. Here is the whole indicator block markdown:
Estimated Location: {{value-0}}
Configured Location: {{value-1}}
The resulting link is invalid, as {{value-0}} and {{value-1}} both have spaces in the GPS coordinates (as shown in the original post).
You can use the encodeURIComponent helper:
(https://www.google.com/maps/dir/{{encodeURIComponent value-0}}/{{encodeURIComponent value-1}})
Give that a try and let us know how it goes.
Thanks, that did work. I still think it probably makes sense to return the GPS coordinates without the space. I want to say in some areas of the platform the space isn’t there (the workflows I think).
