Export recipe can't handle "#" character in any fields
(1) I use “Export Recipe” to export a recipe.
(2) I click “Add Device Recipe” and load the device recipe I just exported above.
It gives me a “Import failed - Invalid JSON” error.
Is this a bug?
Hi @Wesley_Manning,
I’d like to look into this a bit further, could you possibly attach the recipe you have exported?
Thanks so much!
Actually seems like the export is the issue.
Export does like any “#” characters in any fields it appears. I removed “###############” from the “Name” field and “#name#” from one of the tag value fields we had and now it works fine.
We use “#” as a placeholder to tell us to change this on device creation.
Is that a bug or just a limitation on JSON? If can’t accept might be good to warn user.
Once it gets to a “#” character export stops at that point. There is no warning. I found this out by opening the exported recipe in a text file.
Hi @Wesley_Manning,
Thank you for that information! Our engineering team has created a ticket and is working on a fix for this issue; I will follow up as soon as this is released.
Thanks so much for your patience,
