I am learning about Losant by showing data gathered from a Particle.io Argon in a time series graph. I have followed the Particle integration instructions and have a workflow where I can see the latest data from the Argon in the debug window.
I can’t figure out the next step of taking this data into a time series graph. Is there a tutorial I’ve overlooked or some concept I don’t yet understand? Perhaps integration → device → graph?
I have this working. For anyone else who finds this:
Particle integration → JSON Decode to the change the payload data to something a device will accept. From there a time series graph can display the data.
Welcome to the Losant forums, we’re happy you’re here!
Would you be able to share the instructions you were following for integrating particle? What was the issue that you were running into before you used the JSON Decode Node?
I’d love to learn more about your root issue. But I am very happy to hear that you were able to get things working!
I think my issue was a lack of conceptual understanding of the overall structure of data flow in Losant. Then, I had trouble with the syntax and how values are entered into several different webpages. Once I had the workflow engine, devices, and dashboards open in separate browser tabs, it was easier to get everything synced.
