ESP8266 Battery Monitor fails to connect to losant
Please I am having difficulty connecting my esp8266 battery monitor device to losant. I kept having this failure message: “esp8266 failed to authorize device to losant.validation error: the device id, access key, or access secret is not in the proper format”.
Here is my code:
   An example showing how to put ESP8266 into Deep-sleep mode
#include <ESP8266WiFi.h>
#include <Losant.h>
// WiFi credentials.
const char* WIFI_SSID = "Infinix Note 5";
const char* WIFI_PASS = "xxxxxxxxx";
// Losant credentials.
const char* LOSANT_DEVICE_ID = "5c6d7cbb9833d90008816887";
const char* LOSANT_ACCESS_KEY = "***";
const char* LOSANT_ACCESS_SECRET = "***";
WiFiClientSecure wifiClient;
void connect() {
  // Connect to Wifi.
  Serial.println();
  Serial.println();
  Serial.println(WIFI_SSID);
  WiFi.persistent(false);
  WiFi.mode(WIFI_OFF);
  WiFi.mode(WIFI_STA);
  unsigned long wifiConnectStart = millis();
    // Check to see if
      Serial.println("Failed to connect to WiFi. Please verify credentials: ");
      delay(10000);
    delay(500);
    Serial.println("...");
    // Only try for 5 seconds.
    if (millis() - wifiConnectStart > 15000) {
      Serial.println("Failed to connect to WiFi");
      return;
  Serial.println("");
  Serial.println();
  HTTPClient http;
         "deviceId": "575ecf887ae143cd83dc4aa2",
         "key": "this_would_be_the_key",
         "secret": "this_would_be_the_secret"
  root["5c6d7cbb9833d90008816887"] = LOSANT_DEVICE_ID;
  root["***"] = LOSANT_ACCESS_KEY;
  root["***"] = LOSANT_ACCESS_SECRET;
  String buffer;
  root.printTo(buffer);
  if (httpCode > 0) {
    if (httpCode == HTTP_CODE_OK) {
    } else {
      if (httpCode == 400) {
      } else if (httpCode == 401) {
      } else {
      Serial.println("Current Credentials: ");
      Serial.println("Device id: ");
      Serial.println(LOSANT_DEVICE_ID);
      Serial.println("Access Key: ");
      Serial.println(LOSANT_ACCESS_KEY);
      Serial.println("Access Secret: ");
      Serial.println(LOSANT_ACCESS_SECRET);
      return;
  } else {
    return;
  http.end();
  while (!device.connected()) {
    delay(1000);
    Serial.print(".");
  Serial.println("Connected!");
void reportTemp(double degreesC) {
  root["tempC"] = degreesC;
  device.sendState(root);
void setup() {
  Serial.begin(115200);
  Serial.setTimeout(2000);
  while (!Serial) { }
  Serial.println("Running Deep Sleep Firmware!");
  connect();
  int temp = analogRead(A0);
  double degreesC = temp*(27/1024.0)*1.0;
  Serial.println();
  Serial.print("Voltage V: ");
  Serial.println(degreesC);
  Serial.println();
  reportTemp(degreesC);
  Serial.println("Going into deep sleep for 20 seconds");
  ESP.deepSleep(20e6); // 20e6 is 20 microseconds
void loop() {
Please anyone with idea what I could do to resolve my connection issue?
Hi @Johnson_Ogbe,
First thing, you shouldn’t share your access key/secret :). Device IDs are okay. I edited your post to take those out. But, I recommend regenerating those.
Second, I think I see your problem. It’s in this line:
  root["**"] = LOSANT_ACCESS_KEY;
  String buffer;
It should just be:
  String buffer;
No need to recopy your credentials here. The only place you should put your Losant credentials are here:
const char* LOSANT_DEVICE_ID = "device-id";
const char* LOSANT_ACCESS_KEY = "access-key";
const char* LOSANT_ACCESS_SECRET = "access-key";
Thanks bro, you did it. your suggestion solved it.
Please I am stuck sending my payload: my voltage is not been sent/received by losant. the code seems not to be sending the voltage to losant: please help me out.
My code again pls:
#include <Losant.h>
const char* WIFI_SSID = “Infinix Note 5”;
const char* WIFI_PASS = “xxxxxxxxxxxxxxx”;
const char* LOSANT_DEVICE_ID = “5c6d7cbb9833d90008816887”;
const char* LOSANT_ACCESS_KEY = “xxxxxxxx-xxxxxxxxx-xxxxxxx”;
const char* LOSANT_ACCESS_SECRET = “xxxxxxxxxxxxx-xxxxxxxxxxxxxxxx-xxxxxxxxxxx”;
void connect() {
// Connect to Wifi.
Serial.println();
Serial.println();
// Check to see if
delay(10000);
delay(500);
  return;
Serial.println("");
Serial.println(“WiFi connected”);
Serial.println();
Serial.print(“Connecting to Losant…”);
Serial.print(“Authenticating Device…”);
HTTPClient http;
http.begin(“http://api.losant.com/auth/device”);
http.addHeader(“Content-Type”, “application/json”);
http.addHeader(“Accept”, “application/json”);
“deviceId”: “575ecf887ae143cd83dc4aa2”,
“key”: “this_would_be_the_key”,
“secret”: “this_would_be_the_secret”
root[“deviceId”] = LOSANT_DEVICE_ID;
root[“key”] = LOSANT_ACCESS_KEY;
root[“secret”] = LOSANT_ACCESS_SECRET;
String buffer;
if (httpCode > 0) {
Serial.println(“This device is authorized!”);
} else {
Serial.println(“Failed to authorize device to Losant.”);
Serial.println(“Validation error: The device ID, access key, or access secret is not in the proper format.”);
Serial.println(“Invalid credentials to Losant: Please double-check the device ID, access key, and access secret.”);
} else {
Serial.println(“Unknown response from API”);
return;
} else {
Serial.println(“Failed to connect to Losant API.”);
return;
http.end();
delay(1000);
Serial.print(".");
Serial.println(“Connected!”);
Serial.println(“This device is now ready for use!”);
root[“tempC”] = degreesC;
void setup() {
while (!Serial) { }
Serial.println(“Device Started”);
Serial.println(“Running Deep Sleep Firmware!”);
connect();
Serial.println();
Serial.println();
Serial.println(“Going into deep sleep for 20 seconds”);
void loop() {
