Embed widget in custom page
I’m testing the platform and currently I’d like to embed a widget into an experience view page of type custom.
I tried pasting widget embedded code into the custom page, but when I do so I automatically get logged out from Losant page.
It also happens if I paste the embedded code into JsFiddle.
Hi @nahuel,
Could you provide a link to the dashboard you are pulling the block from? I will send you a private message for that information. I was able to replicate a “refreshing” that occurs with the embedded block, but can do further testing with your dashboardID.
Hi @nahuel,
Thank you for providing those details! I took a closer look behind the scenes and it looks as though you are being logged out as your dashboard is set to private. You will be able to embed a single block only if your dashboard is set to public. You can browse our documentation on embedding single blocks and full dashboards here.
Hi Julia,
I’ve checked and the Dashboard is set to public but I still keep getting logged out when I visit the custom page that holds that embedded widget.
Hi @nahuel,
Sorry this is occurring, I was able to replicate the log out with a public dashboard as well. I will inform our engineers, and let you know shortly if we find a solution.
Thank you so much for your patience! :smile:
Hi @JuliaKempf,
Any news about this issue?
Hi Nahuel,
A solution has not yet gone live for this problem. I have found the log out happens in Chrome, while Safari causes the Losant page to only refresh and not log out. Currently, I am able to work around it by having the two pages in different browser windows, but I will update you once the permanent solution is in place.
Thanks. I’ll give your workaround a try.
I have another question :smile:
Since both, the dashboard and the custom page, are hosted on Losant is there a way of embedding the widget into the custom page without having to make dashboard public?
Hi @nahuel,
Currently there is not a way to embed one block unless the dashboard is public, but I will make a feature request for this functionality. If you are trying to embed a custom block that does not use Losant state data, you could also directly put it on the page instead of in a block (for example, the stopwatch JS library you referenced previously). Otherwise, you could also display the entire private dashboard with a Dashboard Experience Page.
