Edge device triggering workflow
I’m having a memory lapse on how I can make an edge workflow trigger a virtual button in an application workflow.
If that is not possible, what are my best options?
Hey @Lars_Andersson,
Your best route is to use an MQTT output node in your Edge workflow with a custom topic that an Application Workflow, with the MQTT trigger, is “listening” to. You would need to make sure that the access key & secret pair has “Additional MQTT Access” set to either All Topics or has the custom topics you will use specified.
Let me know if you have any other questions!
ok, I ended up using a webhook, but I would think your suggestion is more secure.
