Just updated to a Pi to the latest agent version, but it keeps rebooting.
Where are the log files again so I can see why it’s rebooting.
Hi Lars,
It depends on where you configured it: https://docs.losant.com/edge-compute/edge-agent-usage/#configuration-file-example
This is where I’m a bit rusty.
I can not find this config.toml file
Hi @Lars_Andersson,
Can you confirm if you ran with a Configuration File or Environment Config?
looks like Environment config
Hi Lars,
The Environment Config does not have a config.toml file. You can find a list of all Environment Variable options here.
Yes I am starting to understand how it works now. So running that way would not create a log file?
If your Docker command has only the three required Environment Variables (DEVICE_ID, ACCESS_KEY, ACCESS_SECRET), you will not create a log file. However, the options linked above will allow you to set other Environment Variables, such as LOGGER_OUT or LOGGER_LEVEL which are synonymous with the Configuration File options logger.out and logger.level.
