My understanding is that with the latest update, the Device List should show last value for each attribute in each column even if the values were reported at different times. However, I’m only seeing a value for the last attribute reported by the device. For example:
I used the “Device Actions -> Force State” to write values for the battery %, temperature, and tilt (in that order).
Hi @Brian_Ritter,
Could you include a screenshot of your block configuration? If possible, a screenshot of the device log with the three variables would also be helpful, but may not be accessible.
Hi @Brian_Ritter,
Our engineering team has successfully replicated this issue. A fix will be released shortly, and I will update you when it has gone out!
Great, thanks! In case it helps, here’s my block configuration:
Hi @Brian_Ritter,
I wanted to update you that a fix has been released for this! Please let me know if you run into any further issues
