I’m trying to use the “Data Transformation”, with expression for transforming my data. I want to print in the Gauge of the Dashboard the subtraction of two attributes of a device, like:
“sysDiskTotal” - “sysDiskUsedAvg” = sysDiskAvailable
“sysDiskAvailable” is the variable that I actualy don’t have and want to calculate. How I supose to do that?
I tried:
{{value}}-{{ctx.childrenId.sysDiskUsedAvg}}
Hi @Kaue_Delazzeri,
I have a couple of clarifying questions that will help us assist you on this issue - I believe you may be running into an issue in which the ctx variable has not been defined properly:
Is the value being used for sysDiskUsedAvg static or dynamic? Meaning is this a defined device attribute that is reported on the payload as part of the device state?
How have you defined the context variable sysDiskUsedAvg in your dashboard? Could you send along a screenshot of your configuration?
@Aidan_Zebertavage
The ctx variable has been defined properly, when I plot/show them (alone) it’s alright:
sysDiskTotal:
sysDiskUsedAvg:
The only question here is: can/how I use two variables in the Expression Data Transformation in the Gauge?
@Kaue_Delazzeri,
Thanks for the additional information. We are working through this on our end. Would you be able to send along a screenshot of your actual ctx variable configuration from your Dashboard Settings?
@Aidan_Zebertavage
