Data point via manual entry
I have an application where some time series data needs to be collected and entered manually. Possible also with some descriptive text.
I could probably do this with input blocks in a dashboard, but some variables might be conditional depending on other filled out data. Do you recommend any online form builder that would exchange data easily with Losant? Google forms, jotform or similar…
Hi Lars,
I looked through some blog posts and external documentation and found a couple of services that have this functionality, but your use case may be the deciding factor! The basic functionality you will need from a service is a POST and GET to send the data to and from Losant.
