Calculate delta between values of two rows of table
I add every hour a value (total number of written data) to a table in Losant.
Now I want to display the delta between the two entries (last and before last) of the table.
Any help ?
Regards
Holger
Currently dashboards are centered around displaying device data. Data Tables are a brand new additional to our platform and we’re still investigating the best ways to expose the ability to display data from those.
An interesting work-around for now could be to record the delta onto device state. You can setup a timer to trigger once an hour. The workflow could then retrieve the most recent two entries from the data table, calculate the delta, and record it on a device’s state. Once the value is on a device state, you can display it using any number of dashboard blocks.
thanks for your suggestion.
I finally solved it this way:
I used “Storage GET” and “Storage SET” and calculated the difference in a MATH item.
(Note: The “Storage GET” has to be connected to the data flow, despite it does not use the input)
The result could be sent to a device or table adn then used to trigger some events.
Thanks for the great tool. I really like losant
