I get some raw 4-20mA signals in a payload.
Is the best way for me to scale this by using a math node to show the proper value in a dashboard?
I end up with one non scaled attribute and one scaled one for the same value.
Hi @Lars_Andersson,
You say you have two attributes stored for the scaled and unscaled values, are you hoping to reduce to only have one attribute (unscaled) but display it as scaled?
I really only care about the scaled one
I would recommend scaling in the workflow with the Math Node, or, should the Math Node not suffice, the Function Node would also allow you to scale with a formula.
