Hello, what is the payload object format for Allen-Bradley Read Node?
I didn’t want to use the fields manually.
When using the Payload Path option for the Allen-Bradley: Read Node, the value at the resulting path should be an array of objects with the following properties:
key: The key at which to store the value returned by this read instruction (will be stored on the node’s Result Path). Defaults to the value oftagif not provided. -
tag: The Allen-Bradley tag to read. This field is required. -
program: The Program, if needed (defaults tonullif not provided). -
type: The Data Type (defaults to “ATOMIC” if not provided).
Based on your question I’m going to make a ticket to add this information to our documentation; it’s missing from a number of nodes that accept payload paths or JSON templates for instructions.
