Hello!
Simple question: how do I properly access the set dashboard time? I’m trying to do this in an input control button:
But the payload result is:
Thanks in advance!
Hello!
Thanks in advance!
Currently the Input Controls Block will only pass through static defined values, and values that are reflected in the form elements within the block - but I think what you are asking for here is reasonable to expect. I will file a feature request to allow for passing in values from the dashboard properties, including the current dashboard time. Thanks for the feedback.
Hi @Cesar_Guedes ,
Just wanted to follow up on this thread. With our most recent platform update, the Input Controls Block can now pass in values from dashboard properties, including {{dashboard.time}}.
One consideration though - {{dashboard.time}} will only return a value if the dashboard is viewing a past state. Therefore, if no value is returned, we can assume that the current payload’s time value is the same as the dashboard time.
In a workflow, you can use the defaultTo and formatDate format helpers to evaluate if a value was returned by {{dashboard.time}}, and use the current payload’s time value if not. For example, if your Input Controls Block is storing {{dashboard.time}} as data.dashboardTime, you could use the following expression in a workflow node:
{{defaultTo data.dashboardTime (formatDate time 'x')}}
Thanks for bringing up this feature request! Let me know if you have any questions.
