Is there a way to save work in progress workflows WITHOUT having all the nodes required fields filled out? There should be an option on the Save & Deploy button to just Save. Even if a node is incomplete. Unless I’m missing something we have to make sure each node is perfect before saving the entire workflow. This means someone could spend 30 minutes dropping nodes onto the page to rough out a workflow but not be able to step away with an incomplete node without having to delete it if one of the require fields is missing from it.
It would be nice to be able to drop an incomplete node to roughly visualize the flow, save it, step away, and come back to the work.
