Why do I get different Javascript errors in Chrome's interpreter vs. Losant Function node?
I had this code in a Function node:
var test;
test.start_time_ms = 100;
This node returns an error: “Cannot set property ‘start_time_ms’ of undefined.”
If I switch to this, then the error goes away:
var test = {};
Strangely, I am able to use the original example in Chrome’s console without any errors. The field/property start_time_ms seems to be created-on-assignment using Chrome, but not using the Function node.
Is the Function-node’s JS interpreter acting differently from Chrome’s in this situation, or is there another explanation?
Hmm. That’s odd.
Here is what I get in Dev Tools:
But, overall, I’d recommend using:
That way, you clearly create the object.
Or:
const test = { start_time_ms: 100 };
Ah, my mistake - just checked again, and I get the same results as you. Not sure what happened the first time I tested. Thanks!
