SQL Where Statement
OK, I hope this is an obvious one. Can I use a WHERE statement in the SQL node? ALL of your examples are of the format “select * from table” without an example of some like “select * from table where UserID = ‘smith’”. I have tried multiple variations of syntax. What am I missing here? I am scheduled to visit your office on Tuesday, so you can hit me with the “stupid stick” if you like…
Hey @David_MacKenzie,
Are you getting an error when you attempt the where statement? If so, could you send me a screenshot of that error?
Would you also be able to share a screenshot of your SQL Node configuration?
My query is SELECT * FROM RanpakValidationSN where SerialNumber = “R50”
· “errors”:
“SELECT * FROM RanpakValidationSN where SerialNumber = “R50” - ER_BAD_FIELD_ERROR: Unknown column ‘SerialNumber’ in ‘where clause’”
The thing is, there is a column called SerialNumber.
Nevermind close it out. My table only has one column. I had a hunch to try adding another column. Now it works. Nothing else changes.
The query is: SELECT * FROM RanpakValidationSN where SerialNumber = “R05”
I have no clue why this fixed it.
@David_MacKenzie,
Glad you were able to get things figured out!
