Set storage block error
We noticed that the storage node is not loading in the workflow, when opening, moving or inserting the block the following error message appears:
The error was found only in the set value, get is working normally.
Sincerely,
Hello @Andressa_Borre,
Thank you for bringing this to our attention! I was able to reproduce this error, and our engineering team is working on a fix.
I will keep you updated as learn more about this.
A fix has been rolled out for this issue.
Thank you, again, for bringing this to our attention!
Regards,
