Hi there,
I have quite a common use case that right now I am implementing via a node function.
The typical use case is an array of dicts with a set of properties.
All I do is to transform into a dict by selecting a key and a value from the dicts of arrays.
Example below:
"signals": [
"device": "65535",
"functionMedium": "Instantaneous value",
"name": "E",
"physicalQuantity": "E",
"storage": "0",
"tariff": "4294967295",
"unit": "-",
"value": "0.00"
"device": "65535",
"name": "Flow_Volume",
"physicalQuantity": "Volume",
"storage": "0",
"unit": "m^3",
"value": "2.92"
"device": "65535",
"name": "Delta_T",
"physicalQuantity": "Temperature difference",
"storage": "0",
"unit": "K",
"value": "0.09"
"device": "65535",
"name": "Return_T",
"physicalQuantity": "Return temperature",
"storage": "0",
"unit": "°C",
"value": "23.53"
"device": "65535",
"name": "Flow_T",
"physicalQuantity": "Flow temperature",
"storage": "0",
"unit": "°C",
"value": "23.63"
"device": "65535",
"name": "Flow_Speed",
"physicalQuantity": "m/s",
"storage": "0",
"unit": "-",
"value": "0.00"
"device": "65535",
"name": "Energy",
"physicalQuantity": "Energy",
"storage": "0",
"unit": "Wh",
"value": "9900.82"
"device": "65535",
"name": "Power",
"physicalQuantity": "Power",
"storage": "0",
"unit": "W",
"value": "0.00"
"device": "65535",
"name": "Return_Volume",
"storage": "0",
"unit": "m^3",
"value": "0.00"
This will become:
{ "Return_Volume": 0.0,"Power": 0.00, ... }
