MQTT publishing error
My device is connecting via MQTT, but I get the warning “Publish Error - Retain not allowed”
Yes, we do not support retained messages when connecting to our broker. You can read more about this and other limitations in our documentation.
Ah, OK. Unfortunately I have no way of turning that off on my side.
How can I post sensor data via API?
You can use the Device: Send State endpoint. You’ll want to authenticate the request using an application token.
Note, we do have API clients in a few languages that might make this easier for you
ok, I’m doing a POST http request from Node Red with like this:
https://api.losant.com/applications/APPLICATION_ID/devices/DEVICE_ID/state
but I get the response :
{"type":"Validation","message":"deviceState is required"}
What does the body of your request look like? Sounds like it’s either malformed or not included at all.
Here’s an example request body you can check against.
