I’m connecting to losant over MQTT using a raspberry pi with MQTT Paho C. I can successfully connect over tcp, tls, and ws, but not wss.
The SSL negotiation succeeds, but I get the message “WebSocket upgrade read not complete”. When I connect over ws, this websocket upgrade does succeed.
After the SSL negotiation, it sends a connect message, but instead of getting a CONNACK I receive:
<- PUBACK msgid: 21584
<- PUBCOMP msgid: 25701
<- PUBREL msgid 8301
then my side sends a -> PUBCOMP msgid 8301
then the connect fails.
The Root certificate seems to be correct, I’ve tried both default and downloading your root-CA, and both give the same result. I’ve also set the username/password correctly, as it works over the other 3 methods.
hostname: wss://broker.losant.com:443
clientID: deviceID
topic: losant/deviceID/state
username: my_username
password: my_password
The only thing I really change between all 4 methods is the hostname, but for whatever reason it doesn’t work for wss. I have no firewalls installed on the pi, and the router isn’t blocking http traffic.
Have you ever seen something like this before? Or have any ideas on what might be causing this?
