Math node 'null' answer value is not actually 'null'
When you try to do an operation with the Math Node and in the ‘expression field’ you pass a string instead of a valid number, it will return ‘null’ as the answer. That is correct and the expected behavior.
However, if you try to use the Conditional Node to compare if the result of the Math Node is equal to ‘null’, it will always say that it’s not null, even when you pass an invalid number to the math node and the answer is clearly ‘null’ when you look at the payload.
It seems like the value we see in the payload is not the real value the variable is assuming. I’ve investigated this behavior and discovered that if, after passing by the Math Node, you pass the payload by a "JSON encode & decode’ or by an empty ‘Function Node’, it starts to behavior like it should and the Conditional Node that compares if it’s ‘null’ evaluates to true.
This problem is easily seen in the attached workflow and seems to only affect ‘null’ values coming from the Math Node (‘null’ values set with the Mutate Node work properly).
Thanks in advance!
The attached file that Adrian mentioned
testing-workflow-develop.flow (6.4 KB)
Hello @Adrian_Franzoi_Mazzo,
Welcome to the Losant Forums!
@Kelvin_Andrade1, thank you for including the workflow!
What you are experiencing is one of JavaScript’s most well-known “features”: == vs ===, or “Loose Equality” vs “Strict Equality”.
Strict Equality compares both type and value, where Loose Equality does Type Coercion (converts both values to a common type) and then compares them.
In your first conditional node, you have {{decodedWorking.validation}} == null , since {{decodedWorking}} is not on the payload, it is undefined. undefined is a Falsy JavaScript Value, null is as well. So, with loosely testing equality with ==, undefined == null is True because both values are falsy values.
If you do the same with ===, you get:
In your second conditional node, you have {{working.validation}} which is a null value, and are comparing it to null. Just as before, because null is a falsy value, null == null will result in a True path. But, comparing null to itself with === will also result in a True path because null is equal to itself in both type and value.
I would highly recommend that you check out this article or this article as they both go in-depth on the difference between == and ===, as well as Truthy and Falsy values.
Please let me know if this does not answer your concerns.
Hello @Heath,
Thanks for your quick answer. Sorry, my flow misguided you, because it was using {{decodedWorking.validation}} in the first conditional, which is the comparison I should do when the ‘JSON Encode & Decode’ blocks are inserted in the flow. Please, change the first comparison just to {{working.validation}} and you will see the bug I’m talking about. The first conditional will evaluate to false and the second one to true. Later, if you just add the Empty Function Node between the Mutate and the Conditional Node, you will see that both conditionals will correctly evaluate to true.
The problem is not about 'Equality" vs “Strict Equality”. You can even try putting == or === and the same problem will occur (I’ve tested this before). I’m pretty convinced it’s a small bug.
To make it easier to you, I’ve included all the cases I’m talking about in parallel flows, you just have to click the virtual buttons to see the bug (Kelvin will add the flow).
Thanks for your attention and contact me if you need more information.
null-bug-develop.flow (13.9 KB)
@Kelvin_Andrade1 @Adrian_Franzoi_Mazzo I see what you mean now; I think this has to do with the serialization of JSON for JavaScript values that do not have a direct, corresponding value in JSON. In this case that would be NaN, or "Not a Number", and our casting NaN to null when passing through JSON encoders and the handing of the payload to the Function Node.
That said, I’ve passed this on to the engineering team for further analysis, and I will let you know what they have to say about this - whether it’s a bug or expected behavior. Thank you for bringing it to our attention.
I’m curious, what led you to discovering this issue? Is there a use case you are trying to implement that this is blocking you on? If so, can you describe it? I may be able to offer an alternative.
Thanks for the explanation, @Dylan_Schuster! It is probably this casting of NaN to null that you mentioned.
I discovered this behavior when I tried to do a fast verification if a value informed by the user was a valid number or not. I assume there are more sophisticated ways of doing it, for instance using the ‘Validate Payload’, but I saw a quick way of doing it using the Math node. The idea was just to try to multiply the value received by 2 and if the result was ‘null’, that means the input was not a valid number (for instance ‘1t43.40’).
Then I discovered the issue, but this is not blocking us by any means.
Hello
I’m dealing with the same issue.
In my case, i used a conditional node to check if the result from this math node returned a valid number. I couln’t only check if the value is falsy, like !!{{sumResult}} because the value 0 is also a valid result in my use case.
Using a mutate node to create a variable with {{typeof sumResult}}, it will result “number”. But if you cast {{typeof sumResult}} in the debug Payload Tester, it results undefined.
So, by testing {{typeof sumResult}} == 'number' in the payload tester (Expression Input type), it results false as expected, but in the flow execution, it returns true.
test-develop.flow (5.6 KB)
Yes, it’s a very odd case because of the convergence of several things …
  • ‘a string’ + ‘another string’ in JavaScript returns NaN (or “Not a Number”)
  • And, for some reason typeof NaN is “number” (???!?!?)
  • And, JSON does not support NaN so serializing the payload to JSON, as we do when sending through to the debug stream, this gets converted to null
    • However, the actual value on the payload as it moves through our workflow runners is not serialized so it remains NaN
    • And, the payload tester evaluates expressions client-side, in the browser, using the serialized payload while the workflow nodes are evaluated server-side using the non-serialized payload, leading to the difference
I’m raising this issue to the engineering team again but if the goal is to know, in a Conditional Node, whether a value on the payload is not falsy (i.e. the math operation succeeded) but could be 0, you could use the following expression …
!!{{sumResult}} || {{sumResult}} === 0
Just to follow up on this, our latest platform release deals with this odd case. The conditional statement in your example flow should reflect the expected behavior now. Thanks!
