Losant Date format trouble
Hello! I’m trying to compare dates but I’m having problems with the format of the Losant date. Is there a way to convert it to ISO or another way to compare it?
Thanks :slight_smile:
Have you tried the {{formatDate}} helper? From our documentation:
{{formatDate val formatStr}} : Casts the given value as a date, and then formats it using the formatStr parameter (default ‘L LTS’). When used in a dashboard, this will use the current browser locale when formatting.
If that does not work, you can also try the Date/Time Node to convert your date to a comparable format.
If those fail, you could try a Function Node, though that requires a working knowledge of JavaScript to utilize.
