Hi, i’m trying to use the node Object Assign, but the node is returning the error :
InvalidJsonError
template did not render to valid JSON.
I tried to use double quotes, triple brackets, jsonEncode, without double quotes, but nothing.
What I observed is that when my string “additional_description” doesn’t have line breaks, the workflow works.
In the figure below, my string have line break, causing error.
How can I solve that?
I got it to work by doing the following:
So, instead of "prop": "{{path.to.string.value}}", try "prop": {{jsonEncode path.to.string.value}}.
Hi Dylan,
I’ve already tried this before, but returns the same error.
I forgot to say that this value can be null, so may be working.machineOrder.additional_description (in my example) cannot be found.
I can do currentOrder: {{ jsonEncode working.machineOrder }} too, but again, this value can be null, that is the reason that i’m using double quotes.
So, how can I proceed?
To contextualize: the machineOrder values are coming from an array that is returned from Table: Get Rows node.
Im using the array node just to assign the first value from the array tableResult to working.machineOrder
I found a solution.
I removed the object node and used function node, my code:
payload.working.mappedMachine = {
lat: payload.working.mac.tags.inPlantLat[0],
long: payload.working.mac.tags.inPlantLong[0],
patrimony: payload.working.mac.tags.patrimony[0],
condition: payload.working.mac.compositeState.condition.value,
connectionInfo: {
connected: payload.working.mac.connectionInfo.connected,
time: payload.working.mac.connectionInfo.time
alarms: {
totalHealthy: payload.working.mac.compositeState.totalSaudavel.value,
totalWarning: payload.working.mac.compositeState.totalAlerta.value,
totalCritical: payload.working.mac.compositeState.totalCritico.value
indicators: {
om_c: payload.working.points?.om_c ?? "",
hmp: payload.working.points?.hmp ?? "",
tmef: payload.working.points?.tmef ?? "",
tmpr: payload.working.points?.tmpr ?? "",
te: payload.working.points?.te, ?? ""
cost: payload.working.points?.cost ?? ""
currentOrder: {
id: payload.working.machineOrder?.id ?? "",
description: payload.working.machineOrder?.description ?? "",
notifierName: payload.working.machineOrder?.notifier_name ?? "",
notifierPhone: payload.working.machineOrder?.notifier_phone ?? "",
conclusionDate: payload.working.machineOrder?.conclusion_date ?? "",
additionalDescription: payload.working.machineOrder?.additional_description ?? "",
employee: payload.working.machineOrder?.employee ?? ""
This works, but idk if this is a good solution.
I’m still not seeing the problem you are describing, as {{jsonEncode path.to.null.value}} (unquoted) is still outputting the expected result for me. See attached.
Can you PM me the workflow export file and a sample payload?
