Insert custom HTML dashboard update period
Is there a way to insert the update period in the Custom HTML Block?
Same as in the example below:
@lucasbtsuchiya,
Hello!
Currently, you can do this within your block using HTML/CSS/JS.
Every time the block refreshes, you append your own time to the UI every time the queryChange changes.
However, I can make that feature request for you.
It’s ok.
It would look something like this:
var update = DashboardBlock.input.queries.testingupdate.time;
document.getElementById (“update”). innerHTML = update;
Updated
Does the ".time" of the query return the last updated value of the query?
