The query being used.
"$and": [
"scheduleId": {
"$in": "{{data.query.id}}",
"$ci": true
Returns a validation error at the output location -
"message": "scheduleId: value for $in must be an array"
A simple mutate that pushes the type ({{typeof data.query.id}}) outputs array.
A thing cannot be an array and not an array at the same time.
Hi @Travis_Rhoden, and welcome to the Losant Forums.
The default Handlebars behavior when using an expression to evaluate an array is similar to the JavaScript Array.prototype.toString() method. I couldn’t find this in their documentation but you can reproduce it on their website:
https://handlebarsjs.com/examples/literal-segments.html
So in your case, data.query.id may be an array but rendering it as you are in this template will output it as a comma-separated string - and if it did output as an array, it would still be treated as a string in the request because of the quotes "" you wrapped the value with.
What you want to use instead is Losant’s {{jsonEncode}} helper like so:
"$and": [
"scheduleId": {
"$in": {{jsonEncode data.query.id}},
"$ci": true
I encourage you to test your templates out in our built-in workflow template tester if you run into these kinds of unexpected issues in the future.
Hopefully this helps. Let us know if you have any other questions.
