I am trying to access the value of an attribute tag from a device in a workflow using the javascript node. The workflow gets the device, all attributes and attribute tags and saves them on the payload. From within the javascript node I try to access an att tag but get an error:
FunctionNodeTypeError
Cannot read properties of undefined (reading 'attributeTags')
The code that is attempting to access the tag is:
/* attribute calc-flow is for airflow, attribute tag ductAreaCuFt holds duct csa */
var ductCsa = Number(4);
ductCsa = Number(payload.working.deviceId.attributes.calc-flow.attributeTags.ductAreaCuFt);
The payload showing in the workflow debug pane is:
How can I acces the value ‘4’ stored in this attribute tag?
Also, what is a way a javascript node can test the payload to see if an element exists before accessing it so the entire workflow won’t error?
First, your problem lies here (emphasis added) -
Dot notation does not support hyphens in property names (along with some other special characters). Instead, you’ll have to use bracket notation for that portion of the path:
payload.working.deviceId.attributes['calc-flow'].attributeTags.ductAreaCuFt
There is! The Function Node supports optional chaining for safely accessing deep object properties that may not exist.
So using your example from above, a safe way to access the property would be …
const myValue = payload.working?.deviceId?.attributes?.['calc-flow']?.attributeTags?.ductAreaCuFt;
Note you need that period before the bracket notation when doing optional chaining.
