I’m trying to use the python rest API here to bulk create devices using an existing recipe. I can’t figure out what the “bulk_info” property should be.
Whenever I send a rest request, I just receive the following response:
{u'failed': 0, u'csvResult': u'', u'created': 0}
Looking at the following example that shows how to directly upload a csv, I am able to successfully upload and create devices using the following CSV:
Name,Description,internal_id aaa,asdf,1 bbb,asdf,2 ccc,asdf,3
I cannot figure out what combination of CSV the server expects as the bulk info.
The schema example is here which says the bulk info should be straight forward but it’s not entirely obvious. Example schema below:
"nameColumn": "myNameColumn",
"descriptionColumn": "column2",
"csv": "a,comma,separated,string,of,input,data"
Here’s my example code that is not working:
my_bulk_info = {
"nameColumn": "Name",
"descriptionColumn": "Description",
"csv": "aaa,asdf,bbb,asdf,ccc,asdf",
"makeUniqueKeySecret":True
client = Client(auth_token=API_ACCESS_TOKEN)
result = client.device_recipe.bulk_create(
applicationId=APPLICATION_ID,
deviceRecipeId=DEVICE_RECIPE_ID,
bulkInfo=my_bulk_info)
print result
