Fail to install paho-mqtt python module using pip
As the title suggests, I’m trying to install the paho-mqtt python module, and it didn’t work. My hardware platform is the Omega2+ and I’m running the lastest firmware. I’ve installed python 2.7.13 and pip. When try to install paho-mqtt with the command pip install paho-mqtt, it fails with this error:
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-Q5_vZE/paho-mqtt/ Exception information: Traceback (most recent call last): File "/tmp/pip-build-oXZg05/pip/pip/basecommand.py", line 215, in main File "/tmp/pip-build-oXZg05/pip/pip/commands/install.py", line 324, in run File "/tmp/pip-build-oXZg05/pip/pip/req/req_set.py", line 380, in prepare_files File "/tmp/pip-build-oXZg05/pip/pip/req/req_set.py", line 634, in _prepare_file File "/tmp/pip-build-oXZg05/pip/pip/req/req_set.py", line 129, in prep_for_dist File "/tmp/pip-build-oXZg05/pip/pip/req/req_install.py", line 439, in run_egg_info File "/tmp/pip-build-oXZg05/pip/pip/utils/__init__.py", line 707, in call_subprocess InstallationError: Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-Q5_vZE/paho-mqtt/
How can I fix this issue?
Hi @Microbob,
You should definitely take a look at the Onion documentation. It’s super helpful. They covered this error here:
It looks like all you need to do is:
pip install --upgrade setuptools
Let me know if this works! If it doesn’t, I can fire up the Omega we have in the office to test.
After running the install command, everything worked! Sorry about not looking into the doc again, that must have been how I fixed the issue before in our first thread :sweat_smile:.
No worries @Microbob, I do it all the time. I’m happy we can figure it out!
